zetor 4320 won't move until left side pops
   / zetor 4320 won't move until left side pops #1
geary
Zetor 4320
after not being run for a few days, tractor starts fine but acts like left brake is engaged. rocking back and forth will cause a loud popping noise after which it seems to be fine. decided to overhaul brakes, but cannot pull final drive off. it moves one-half inch out and stops.
   / zetor 4320 won't move until left side pops #2
this forum has a Zetor section, if ur tractor has a hand brake that uses a band then u will need to
loosen the adjuster or remove it to get the final drive off, do u have the service and parts manual ?
thanks for the heads up on the zetor section. i do have the shop manual and have disconnected the rod from the parking brake cable and tapped it toward the brake with no affect.
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2017 HINO BOX TRUCK (A51222)
2017 HINO BOX...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
