ZETOR 3320
   / ZETOR 3320 #1
texana1
ZETOR 3320
Stuck Tractor and pulled the Hydraulic LINE broke going to pump from Hydraulic Tank,,,,,repaired the line low pressure and filled the tank with Hydraulic oil and now will not build up any pressure for front end Lowder,,,NO Hydraulic OIL IS MOVING
   / ZETOR 3320 #2
Dumb question. Any idea how long the engine ran AFTER the line broke and before you figured out the pump wasn't getting any oil? Running a pump dry can do a lot of damage in a short time. Have you tried removing a line from the top of the pump and slowly adding some oil into it, then trying it again. Sometimes a dry pump will come back after that if you get the gears wet enough to pick up prime.
Tires (A50322)
Tires (A50322)
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2015 Chevrolet Cruze Sedan (A50324)
2015 Chevrolet...
