HomerGuy
I am looking to upgrade the tires on my Toro Titan HD 1500 Zero Turn (uses the ZT3100 transaxles). My property has some significant slope in portions of the backyard, and I frequently find myself sliding down the incline. Thankfully I have a safe landing zone at the bottom of the slope, but it can be rather sketchy and no fun nonetheless. I’d like to find something with a better grip than the existing tires which are Kenda K500 Super Turf in 22x9.50-12. Existing rims are 8” wide.
The 22” size on a 12” diameter rim seems to be a rather unusual size with not many options available. So I’ve been looking at 23” tires which opens up some more possibilities. I know I will need to repitch the deck to accommodate the slightly taller tires. The deck does have enough adjustment to re-pitch it to accomodate a taller tire.
Here are the two options that I am considering
Option 1 - Kenda K502 Terra Trac in 23x10.50-12
I like the idea of a slightly wider tire (10.50 vs 9.50 existing) which I think will improve ride quality over bumps. I have clearance to accommodate a wider tire. This option is also reasonably priced at $190 for two. I see a handful of reviews online but not many. It looks like a good, aggressive tread pattern.
Option 2 - Carlisle (Calstar) Versa Turf in 23x8.50R12
These are radial tires instead of the traditional bias ply. Supposedly the radial construction improves ride quality significantly. This option does seem to get very positive reviews, and the tread pattern is very similar to the Goodyear R14 tires, which leads me to believe it is a good design if multiple tire manufacturers are using similar designs. My biggest worry is that this is narrower than my current tire (8.5" wide vs 9.5" existing), and that decrease in width will adversely affect ride quality. They are also pretty expensive at $315 for a pair.
Any feedback on these two options?
