Zero Turn Mower
   / Zero Turn Mower #1
deereowner
Within 30 miles of Nashville
John Deere LT110, Hustler FasTrak
I am looking at buying a ZTR for my 1.2 acre yard. Lots of trees, odd shaped yard. I am beginning to experience price creep, was looking first at the Cub Cadet ZTR50, then decided I needed to go with the Cub Cadet Z force 50, which had the IZT transmission and Kohler motor.
Now, I made the mistake of looking at a Hustler Fastrak 50, which is now $5000 (I started at $3000 with the ZTR50). Is it worth the difference? I have always believed that quality is worth the cost, but would like to hear from people with real world experience.
Thanks!
P.S. I have a John Deere LT110 that it is replacing, for faster mowing time, and more fun.
   / Zero Turn Mower #2
Either one of these machines would be what you need it to. If I were you I would spend the extra $1000 on the Z-Force 50. I woulnd't be able to justify the other $1000 on the Hustler...not for 1.2 acres. Take the middle ground and you will be very pleased!
   / Zero Turn Mower
How about a used (15 hours) Gravely Promaster 44". I just found a deal at about $3,000 (if the bidding doesn't go up, not much time left)?
Thanks for the information.
   / Zero Turn Mower #5
If you can score the Gravely for less than $4K then jump on it. Gravely makes very good commercial ZTRs. You might also look at its Airens sibling. The Airens 1742 is a highly recommended consumer ZTR.
   / Zero Turn Mower #6
deereowner, Well after seeing your post about the gravely, I hope you jumped on that like a tick on a hound dog!!!
If you missed it I would take gambles sound advice for 1.2 acres... A commercial type ZTR would just be getting warmed up when it was all done /forums/images/graemlins/tongue.gif Can we say overkill /forums/images/graemlins/grin.gif
   / Zero Turn Mower #7
Have you looked at any of the commercial walk-behinds, such as Scag, Exmark, Lesco? These also have a Zero-Turn Radius and are much less in cost.
   / Zero Turn Mower #8
MFMan,
I would hate to think what those ZT MF's would price for! Do you know?
Fig
   / Zero Turn Mower #9
MSRP on them is as follows:
ZT29 (28.4 HP) w/ 60" deck - $11,818
ZT33 (33.0 HP) w/ 72" deck - $13,247
Hope that helps!
   / Zero Turn Mower #10
The bang for the buck on your property: I'll second the ZF50 too.
Now if you can get a full comercial unit (i.e.: all these qualitites instead of mix and match: heavy duty welded frame, deep heavy gage [7 to maybe 10 gage] fabricated [ok JD makes a 7gage deep stamped deck] deck, commercial duty engine with a respectable torque curve, pumps & wheel motors (I think Kubota may use a heavy duty "transmission" though), 15K+ blade rate, etc.) for under $5K you better be all over it....even if overkill for a couple acres as previous noted. /forums/images/graemlins/grin.gif
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 Ford F150 Pickup Truck (A53422)
2014 Ford F150...
68  Root Grapple (A53421)
68 Root Grapple...
2015 Hitachi PC138 (A47477)
2015 Hitachi PC138...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
