Zerks
   / Zerks #1
TGF
Blair, NE
3038E
I was running my rotary cutter this morning, and the recommended that I grease something every time pre-run, which is fine, however, I could not find a zerk in the general area they were telling me to grease. Its the U-joint on the drive shaft going back to the cutter, and they only suggest I grease the one at the tractor and not at the cutter end. Should I just shoot grease into the u-joint as best I can, and should I grease the one on the cutter end?
Sorry if this question seems mundane but I want this tractor to last, every vehicle I have owned I have run well past 100k miles before some driver decided to total it for me, I want this tractor to out live me.
   / Zerks #2
That's kind of odd...all my shafts have zerks at both yokes. Is it possible the zerk has fallen out? You'd be looking for a small threaded hole (about ¼" diameter). Try cleaning off the yoke as best you can...
But maybe that u-joint has sealed bearings...
BTW, who is "they"? The dealer that sold you the cutter?
   / Zerks #3
I have a zerk question and it's not on a tractor...On my 04 GMC, I greased it today and the grease squirted back out of the zerk..I squished it down and the spring works...Only stopped coming out with the zerk depressed.
Put a shelf end cover over it and it didn't have enought pressure to push it off...Ideas?
Don't want to leave it like this.
   / Zerks
Sorry ,they is the manual, in the instructions it just shows greasing the PTO end. Is it possible I need to rotate the U-joint around or should the zerk be in an obvious place?
   / Zerks #5
Rotate the shaft with the mower in the air. There is usually a hole in the plastic guard on the u-joint area that will align with the zerc fitting and you can then get your grease gun on it.
   / Zerks #6
Take a look inside the yoke.
   / Zerks #7
For me I have found that is better just to yank the PTO shaft off and grease it on the workbench. I have tried greasing through the holes provided in the PTO shrouds but found out that I needed a tail so I could hang upside down while trying grease.
   / Zerks #9
MY JD Flail mower has access holes in the shrouds for the zerks. :)
   / Zerks
even with the access hole it seems near impossible to get the u-joint at the clutch plate. I am thinking of making the access hole much bigger.
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
HYDRAULIC FLOOR JACK (A53843)
HYDRAULIC FLOOR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A52705)
2018 CATERPILLAR...
Landoll Lowboy Trailer (A53473)
Landoll Lowboy...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
