Backhoe zerk fittings coming off...
   / zerk fittings coming off... #1
indhrasena.reddy
I've 2615 with 1710b backhoe one of grease fittings is coming off i just want to know how i can fix it, if posible can i have a diagram of it
   / zerk fittings coming off... #2
The 2615 calls for a 3710 backhoe. Anyway, all you need to do is take the loose zerk, (grease fitting) to your local auto parts store, and get the next larger size. Get the self tapping kind unless you want to do it the hard way. I had a similar problem on my loader. It is an easy fix.
   / zerk fittings coming off... #3
As Achingback says, they are threaded. If it is just loose, try to tighten it with a wrench. If it's bent/damaged, or the hole or threads are worn, he has the right answer for you.
- JC
   / zerk fittings coming off... #4
No specific experience here, but this is what I'd try:
Remove the zerk and clean it good with a degreaser or shot of brake cleaner. Do the same for the threaded hole.
Then use a removable threadlocker (loctite-blue?) and put it back in. Then pump some new grease through it.
Good luck.
   / zerk fittings coming off... #5
Backhoes can really wreck havoc on zert fittings.;) I change mine out pretty often down near the bucket.:thumbsup: I gave up cleaning them. Once I found a splitter of wood shoved into one fitting.:mad: A lot of times they get deformed also.
Whatever you do to fix the problem, keep the grease a coming!:D
hugs, Brandi
   / zerk fittings coming off... #6
700' of 6' deep trenching yesterday. Putting a box of new zerks in my "man bag" along with threader. Hope all take grease. Don't want to stand in that mud that sucks your boots off while making a repair. If one gives me trouble, I always replace. I'd just rather replace in the shop than on site.
   / zerk fittings coming off... #7
Usually if a backhoe fitting won't take grease, you just have to move the actuator by trial and error to get it to take grease. I do have an outrigger stabilizer pivot pin that needs to be removed and cleaned to take grease.
hugs, Brandi
   / zerk fittings coming off... #8
hugs, Brandi
I noticed a broken zerk on the outrigger stabilizer pivot pin just yesterday. Will replace it this weekend. (Have a box of replacement zerks just waiting for action.)
   / zerk fittings coming off... #10
I bought a box of 110 of varying size and angles for about 30 bucks. Makes repairs easy and saves money when you consider 6 bucks for a single fitting.
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
