Zenith carb on my 9N?
   / Zenith carb on my 9N? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I either need to rebuild or buy a rebuilt/new Marvel or Zenith carb for my (from FIL) 9N. Just read the post regarding a Zenith on a Ford 850..
Don't know if the results (poorer fuel economy) with the Zenith versus the Marvel will be the same on the 9N.
Anybody use a Zenith on a 9N and have a perspective?
Thanks,
AKfish
   / Zenith carb on my 9N? #2
it will be fine. you can get re-popped MS pattern carbbs from tsc though if you like the look of a ms carb.
fuel consumption on an N will not have a noticed difference between the carbs. the 8xx models, especially with the bigger manifold and air pipe just tend to get hungry.. that's why such the big difference.
soundguy
Thanks, soundguy. Appreciate the help. I'm a "function over form" guy - not so much how it looks - but it should run right!
AKfish
   / Zenith carb on my 9N? #4
while I've rebuilt both.. I tend to think the ms carbs and repops are a lil more user firendly.. plus easier to get kits for.. but that's just my opinion.. etc.
( same carb gasket fits a tsx 33, 241 a-c, 428 and 580 :) )
soundguy
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A53843)
2013 KENWORTH T800...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
