ZD326 Starter issues??
   / ZD326 Starter issues?? #1
Joe Kidd
ZD326
Case in point; 5yr old zero turn ZD326(26hp diesel). I'm having cold starting issues. Starter bendix will click but starter will not engage unless I try starting multiple times. I've tried two batteries. My fixed load battery tester(130A) shows "good" with a 15sec test load. Clean connections from the battery post all the way to the starter. I also checked ground chassis connection. When the starter finally engages it'll drag a good bit but generally will start the engine. After I mow for a while restarts are ok. Can a starter exhibit cold weather problems? I even tried two batteries in parallel with the same end result. Any suggestions welcomed. I did notice a crack in the starter "plastic" between the ground and positive posts.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
