ZD326 Possible temp sender problem?
   / ZD326 Possible temp sender problem? #1
Joe Kidd
ZD326
My temp gauge normally runs about mid scale. Last week it started moving up to about 2/3 towards hot, but it'll stay there for a while then drop back to normal. It'll repeat this during a 2 hour mowing. I've changed the coolant every year, new radiator cap last year. Mower is 14 yrs old with 2200 hrs. Radiator is clean and belt is tight. Upper hose is firm when running, so it's making pressure. I checked the engine temp while running at the temp sender with a IR gun and also near a couple freeze plugs and it's running 180 degrees. I'd suspect the sending unit as opposed to the temp gauge. Temp doesn't change even after running a couple hours(with IR gun check)
Thoughts?
Any recommended thread sealant for that? I've got Rectorseal #5 and Loctite #567.
New Temp sensor fixed the problem.
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A48836)
1996 International...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2018 FREIGHTLINER...
2017 CATERPILLAR 938M WHEEL LOADER (A50458)
2017 CATERPILLAR...
2008 STERLING L9500 TRI AXLE DAY CAB (A50046)
2008 STERLING...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A50046)
2017 UTILITY VS2RA...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
