ZD323-60 Throttle will not stay set above idle
   / ZD323-60 Throttle will not stay set above idle #1
RTJ49
Kubota BX 25 & DZ 323
Hi All,
My ZD-323 will not keep the throttle above idle without holding it by hand. Any ideas how to fix?
Thanks,
RTJ49
   / ZD323-60 Throttle will not stay set above idle #2
Follow the linkage.. I think you'll find some fiber disks that "squeeze" it.. just tighten the screw or get new disks.
BUT just tightening the screw normally takes care of the problem.
   / ZD323-60 Throttle will not stay set above idle #3
Do not know the linkage here but as has been told most likely the design but may have a nut with locking built in that needs to be replaced or a cotter in that needs to be removed and could be missing.
2006 TerraGator 8104 (A53472)
2006 TerraGator...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
