ZD21 Hydraulic Lift
   / ZD21 Hydraulic Lift #1
cm0897
can anyone tell me where the filler hole is for the hydraulic lift for the mower deck? I bought a used ZD21 and it was working fine until now. The deck will not lower, it acts like it need hydraulic fluid, but I can see a place to add it anywhere. If you have had this problem before I would appreciate your help!
   / ZD21 Hydraulic Lift #2
Lift the seat up and the filler hole is covered by a large black cap. There is a dipper stick right beside it for checking the level. The other thing to check is to see if someone moved the knob that sets the height of cut on you. If it is set to 5.0 the deck will not lower as the knob controls the stop to keep the deck from dropping below the setting you choose.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2021 Polaris General XP 4 1000 4x4 Side by Side (A49461)
2021 Polaris...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
1999 FONTAINE 48X102 FLATBED TRAILER (A51222)
1999 FONTAINE...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
