Zd1211 oil
   / Zd1211 oil #1
turbo246
Bronze Member
Kubota zd1211
What weight oil comes from factory in zd1211. My dealer says it’s 10w-30. Is that correct? Wanted to get oil for my first change but wasn’t sure since books says either 10-30 or 15-40
Has anyone swapped to synthetic? I swapped over in my scag with 3cyl diesel with great results. (Amsoil) but that’s a 3cyl turbo that works works hard in the same conditions the kubota purrs through
   / Zd1211 oil #2
Kubota seems to like 10w30 oil, so I suspect your dealer is correct (plus the dealer is prepping machines with lubes).
3 out of 4 Kubota machines I have started using synthetic at the 50h initial service. The other machine was bought used, and also switched out to 5w30 synthetic.
   / Zd1211 oil #3
The dealer does not ‘prep’ Kubota machines with lubes. Lubes are factory filled and checked before retail sale.
7046 (A50322)
7046 (A50322)
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
