ZD1211 Mower Grade zerk
   / ZD1211 Mower Grade zerk #1
RjCorazza
Elite Member
Maryland
Kubota L4060 Cab, ZD1211, ZD326
I was greasing a ZD1211 72" deck today, and found the grease zerk damaged on the"quick release" yoke universal joint. The edge that accepts grease was sheared flat so that the universal can't be greased. The Kubota parts list has a superceded part number for the zerk, so I suspect a design issue was discovered.
Anybody else have this happen?
On edit, sorry for the title error. I hate auto correct!
Disregard. I removed the shaft yesterday to replace the zerk, and upon closer examination, it was not damaged. I guess my old eyes aren't what they used to be.
It is much easier to grease after removing the shaft.
2020 JOHN DEERE 7R210 LOT NUMBER 50 (A53084)
2020 JOHN DEERE...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
