ZD1011 Fuel Consumption and Compare to Z724KW
   / ZD1011 Fuel Consumption and Compare to Z724KW #1
kubotacres
Louisiana
Kubota L3560 HST
Looking at purchasing a ZD1011 and the lack of fuel storage is a disappointment at 6 gallons. The Z700 series has dual tanks but is a gas burner. I know I can step up to the larger Diesel for more storage but it's not practical considering this will only be for residential use only. My question is how the fuel consumption is on the 19 horse Diesel for the 1011 compared to the Kawasaki on the Z724? Any opinions between the two? I'm buying based on the diesel and hydro that is offered on the ZD but I honestly would probably be fine with the Z700 and save a ton of money. Thoughts or opinions?
   / ZD1011 Fuel Consumption and Compare to Z724KW #2
I replaced my old gas ZTR with a diesel. Go with the diesel, even with the smaller capacity. I mow 2 acres around the house and buildings with my ZD1211 every week, uses about 1 gallon of diesel. I like to keep fresh diesel in it. I put in 5 gallons of diesel at a time. Lasts at least a month.
I guess the ZD1011 isn't a popular mower.
   / ZD1011 Fuel Consumption and Compare to Z724KW #4
My ZD331 holds 12.9 gallons In 2 tanks. I think they hold same amount of diesel.
With a 31HP diesel, after 8 hours of pretty strenuous mowing, I use about 10 gallons.
I would think a 19HP diesel would run about an 8 hour day on a full 6 gallon tank.
   / ZD1011 Fuel Consumption and Compare to Z724KW #5
My 28 hp diesel is burning 1/2 gph or so.
With my current 26 hp Kawasaki I'm using around 1.5 gallons an hour and stuck with a 6.5 gallon tank. I'm trying to justify atleast some savings in fuel although I know it won't make up the difference in amount I'll be spending.
   / ZD1011 Fuel Consumption and Compare to Z724KW #7
K
Or people that own them don't complain about them. We sell a half dozen or so every year. Generally we don't see them except for those who choose not to do their own basic service.
Time you burn through 5 or so gallons of diesel you'll be looking to get off and stretch your legs, or you'll be done for the week anyways.
The ZD isn't in the same class as anything in the 700 series.
   / ZD1011 Fuel Consumption and Compare to Z724KW #8
I think you would be fine with the gasser, too but the 6 gallon tank is NOT the reason to walk from the diesel.
A 19HP diesel, as RickB said, will run longer than you’ll want to operate it on 6 gallons.
That's the answer I was looking for. I had initially looked at buying the ZG series but later found out the "Kubota" engine was a rebadged Kohler. I tend to lean more on Kubota built engines whether they cost more or not due to reliability. Which is why I started looking at the diesel. Probably will be pulling the trigger on one soon. The diesel engine will probably outlast the mower.
   / ZD1011 Fuel Consumption and Compare to Z724KW #10
Yep. You’ll like that diesel. I love my ZD 331. It’s very rugged and with sharp blades gives a great finish cut
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
