Mowing zd 331
   / zd 331 #1
catskill_bob
Catskill Mts. New York
BX-22
I bought a ZD331 last year for mowing. I used it 31 hours all year. The mower has been idle since November. I'm wondering if I should get the 50 hour service now or wait until midsummer until I hit the 50 mark. Is there anything I should do to get ready for mowing this spring?
   / zd 331 #2
I have a ZD323 that we used to cut the grass 3 or 4 times last year (bought the place in the fall). I parked it and put a float charger on it over the winter. Added fuel preservative (power diesel or something like that) and removed the pulley tensioning spring on the deck so the belt wouldn't take a set. I also rolled it a couple feet every few weeks to keep the tires from getting a flat spot. I don't plan to do my 50 hour service until 50 hours.
I would guess at the very least you will need to charge the battery. Possibly replace it if it won't take a charge.
-Rob Glaser
   / zd 331 #3
I purchased a ZD21 last year - used it ~50 hours (has a total of 180 hours now) and put it away for the winter (pulled the battery), power serivce for the fuel, grease and WD 40 the moving parts etc. This spring I plan on changing motor oil only and do a complete service when it calls for it.
   / zd 331 #4
I would have changed the oil/filter before you put it away in november....clean it up good and thats it...
2009 Lexus RX350 (A50324)
2009 Lexus RX350...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
1990 International 8300 Vacuum Truck (A47384)
1990 International...
2000 International 4700 Truck (RUNS) (TITLE) (A50774)
2000 International...
2017 Vermeer SC802 S/A Towable Stump Grinder (A50322)
2017 Vermeer SC802...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
