ZD 326 Fuel Tank
   / ZD 326 Fuel Tank #1
Larry Guyton
Kubota ZD 326
I have water in my ZD 236. What is the easiest way to drain the fuel tanks?
   / ZD 326 Fuel Tank #2
I would think at the fuel switch selector. Pop of the line that feeds the engine and drain away. Since you are there, think about getting rid of the left tank right tank selector and replace with a tee.
That method Kubota came up with I just couldn't make sense of so I replaced the selector with tees and remove the light bulb from the right tank low fuel indicator.
2011 John Deere 4520 53HP Loader Utility Tractor (A51691)
2011 John Deere...
2016 Kubota M5660SU (A50123)
2016 Kubota...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2021 Honda 520 Foreman, 4WD  (A52384)
2021 Honda 520...
2017 FREIGHTLINER CASCADIA SLEEPER (A53426)
2017 FREIGHTLINER...
