Z725 reverse problem
   / Z725 reverse problem #1
grandall4
Granby MA
Kubota B2601 & Z725
Is this an easy fix or do I need to visit the dealer?
I have a 1 yr old Z725 with 98 hours. When mowing today I noticed the left side control was not engaging reverse equally to the right. When pulling back, the left side was providing a lot of resistance, almost like it was pressurized. In other words, where the right side moves freely in reverse, the left would only come back a fraction of the usual travel distance of the control. The result is the left wheel was barely turning compared to the right.
Did I lose an adjustment or should I be digger deeper for a solution?
   / Z725 reverse problem #2
Did you physically get under and look at the linkages/mechanism?
Yes, everything is in adjustment with no bends or breaks. I compared all adjustments to the right side and everything looks as it should. The one thing I didn't do was pull the damper on the motion control. The feedback I feel when pulling in reverse is as if there is resistance in the hydro
   / Z725 reverse problem #4
The next step would be to remove the damper to eliminate/prove it as the culprit.
2000 ADDCO DH1000 Message Board (A49461)
2000 ADDCO DH1000...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
