GBHRPS
Bronze Member
Ladies and Gentlemen,
This older Z Force 48 has had several years of difficult starting cold or hot. I don't recall having this issue when I first purchased the unit used. What happens is that you turn the key to start and get a click, turn it off, turn to start and get another click, turn it off, turn to start and get another click, turn it off, and turn it on and the starter turns and fires up the motor with little fanfare.
Its almost as if the starter has stopped at a bad spot on the armature, and then after several part rotations it finally sits at a place where it has enough magnetic pull to turn the crank. The tractor never fails to start, it just takes 5 or 6 key clicks before it catches and turns the crank.
I also own an older JD 175 Hydro (14 HP Kawasaki) that suffered the exact same issue about 10 years into its life. JD had a simple factory kit to solve the issue which cost about $30 way back when. It was a simple automotive relay, a relay socket and about 3 or 4 wires that went to the ignition switch, a ground and the starter as I recall, that totally solved the issue. That old JD is now some 30 years old and turns over and starts first time every time.
Is there a similar solution to my Z Force 48? If so, I'll just copy the JD relay add on and see what occurs. And no, there is nothing wrong with my battery or its cables, ignition switch etc.
Gene
Gene
