Z-force 48 cub cadet 42hours of use, having issues... need help.
   / Z-force 48 cub cadet 42hours of use, having issues... need help. #1
Miguel1309
Miami, Fl
The engine starts with no problems, when I take the brake off to start the ride, the engine goes off. Any thoughts???
   / Z-force 48 cub cadet 42hours of use, having issues... need help. #2
Most likely a safety switch issule. Most likely the seat switch or associated wiring, which could include a relay.
   / Z-force 48 cub cadet 42hours of use, having issues... need help. #3
Make sure the handles are all the way out - either one pulled in just a bit will also kill it. Handles out, release brake, then pull handles in.
If it isn't a problem with the order of brake release/handle use, then it's likely the seat switch. I have a problem with mine every so often, and it about drives me nuts. Sometimes I can just bounce on the seat a bit, but usually I have to get up, lift the seat, pull the switch connector off and on a couple times to re-seat and that does it.
The connectors don't look corroded or anything, but re-seating seems to do it. I'll have to clean them real good sometime...
   / Z-force 48 cub cadet 42hours of use, having issues... need help. #4
Would have to be something with the seat switch. If one of the steering handles was not all the way out with the brake on the engine wouldn't start.
Miquel,
Lift the seat and remove the 2 bolts that holds the seat switch assembly in. There should be enough wiring for you hold the switch assembly in your hand while you're in the seat. Start the engine, squeeze the seat switch, release the brake and see if the engine still dies. If it still dies the seat switch is bad and needs to be replaced. If it didn't die then either(don't take this wrong) you don't weigh enough or there something inside the seat preventing the switch from being pushed maybe a mud dabber nest. The wiring connector for the seat switch has a special feature built in to it to prevent you from just bypassing the switch.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK (A51222)
2012 FREIGHTLINER...
2014 FREIGHTLINER M2 REAR LOADER GARBAGE TRUCK (A51219)
2014 FREIGHTLINER...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
