Z-Force 44 blade pulley grease zerks??
   / Z-Force 44 blade pulley grease zerks?? #1
MesquiteMan
San Marcos, TX
ScatTrak 1750D
I posted this in the Cub forum and then realized I should have posted it here instead.
I bought a z-force 44 a couple of months ago largely due to you guys influence. I have been maintaining it like clock work and have come across something that I don't think is quite right.
The manual shows the count for blade pulley grease zerks as 3. I assume that is one for each blade. For the life of me I can not find one for the center blade pulley. I pulled the deck out from under the machine and noticed the nut on the center pulley has a threaded hole in it where I assume a zerk should have been installed? It is in the same place where the zerks are located on the other pulleys.
Am I right to assume a zerk should have been installed there and was just missed at the factory? If so, is this something I can just pick up at the local autoparts store and how would I know what to ask for?
   / Z-Force 44 blade pulley grease zerks?? #2
There's always something to prove me wrong, but you just won't see a deck that combines greaseless and grease type bearings, so I think your assumptions are dead on. I have seen decks with side zerks situated in nasty positions sideways under the pully, but there again, I doubt they'd combine arrangements. I have no idea what all models are top/center, but from the couple I know well, I always think of top/center zerks on a CC deck, including the middle blade.
The good news is that zerks are pretty standard; just to be sure they aren't using an odd size you can pull out one of the other ones and bring it along. If the auto-stores don't have one, a TSC type place will (probably cheaper, but we're talking <<$1); maybe even the place you bought it from [Home Depot?].
Also good news; bearings often have a little lube from the factory, so I'm betting that you didn't do any damage on a new machine [I'm saying 99% you're probably OK....so don't lose a wink of sleep over it]; but if there is someone to complain about it to, it couldn't hurt [I'd say dealer, but if I remember right you were in the area where the box-store was fairly knowlegable and the dealer....well....much less so].
I think you've posted about it a couple times, but how's it treating you?
Also, you grease your bearings!! /forums/images/graemlins/smile.gif A little maintenance will pay you huge dividends. It makes me cringe when someone spends good money on a machine, then won't spend $20 on a grease gun. /forums/images/graemlins/frown.gif Poor machines.....
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
JLG ELECTRIC MANLIFT (A52472)
JLG ELECTRIC...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
