Z-225 zero turn
/ Z-225 zero turn #1
Bbry0000
Freehold
X225
Oil leaking from fuel pump
Motor stops when hot
Starts after cool down
Smoke comes out of oil dip stick tube
Verified oil level is proper
Any suggestions ??
/ Z-225 zero turn #2
First, how many hours on this machine...and, is it still in warranty?
If in warranty, let the dealer handle it...otherwise, you can void your warranty.
Your engine is air-cooled....so, the first thing to check is that the cooling fins are clean since it really sounds like it's overheating. While you're checking out the cooling fins, I suggest you clean the rest of the machine...and check the air filter.
/ Z-225 zero turn #3
If the cover to the cooling fan is not covered in debris just snap it off and look deeper. I haven't looked at my Z225 but am sure it is driven by the flywheel so it will turn. I agree with Roy Jackson that it is a cleaning problem.
2017 PETERBILT 579 DAY CAB (A63569)
2017 PETERBILT 579...
2007 CATERPILLAR 966H (A63569)
2007 CATERPILLAR...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63118)
Midwestern...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59910)
2020 KENWORTH T680...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
