My property has about 5 springs that converge into a nice stream, It runs approx 100 gals per minute when it reaches the end of my property . I have found the head or source of all the springs. As it is in a cedar bush the small feeder springs soak through the ground and generally make a large area really wet.. Not that this is a problem but I have just cleared all the leaves and debris and I want to put in a small ( 4"?) big O pipe.. The reason is that it will just make it alittle drier around where we have paths going through the bush. I really do not want to hear from the safety police here on what all Im doing wrong. All I want is opinions on whether the plastic Big O (drainage pipe) should be solid to just carry the water to the main stream bed, or should I use perforated ?? Also should I use perforated with a sock?? Just want to get some ideas from people with more experience. The main idea is to keep all the water flowing without the annual falling of leaves etc, clogging it up. I will be building some small bridges ( footpaths) etc. Any suggestions are appreciated. Thank Youl
