Buying Advice Your advise please
   / Your advise please #1
Mohamed Ali
Abu-Dhabi (UAE)
Massey Ferguson/kubota
Hi,
In Tunisia,we have the commun tractors range no more than 95 HP.As a farmer I have a small kubota tractor (L4740-49HP) wich is used for light jobs...
By facing the net, I'm very pleased and attractived by the Massey Ferguson tractors (as I owned an MF275 before) like the MF 5600 and MF 6600.
I have a big Farm (50 hectars) and my land is composed by shale ,which is hard to plow,so my FRIENDS please I need you advice .( my favourite tractor is the MF5612) please your advise will be in concederation becuase I have no idea about this tractor generation.Thank you for every body
   / Your advise please #2
The 6600 series is heavier and available with CVT if you can swing it. Probably better for field work if your doing a lot of it. I don't think you can go wrong with either. The 5600 will have the edge in maneuverability, but the 6600 is short wheelbase as well. Still has a 4 cyl. Both should be fuel misers. I think the CVT will pay for itself in fuel savings over time. You can run a lower RPM when power not needed and still change speeds as needed.
I have 4600, wanted a simple transmission and at time didn't want to pay for 5600 upgrade. (5612 would be nice) But I think my 4610 will do all I need until I grow(my land) and can use a 6600 series to its fullest.
John Deere Z994R (A50121)
John Deere Z994R...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2008 Ford F-250 (A52748)
2008 Ford F-250...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
