You would think he would learn
   / You would think he would learn #2
Wow! Quite a jump!
Something like this happened at a company I'd worked for....
   / You would think he would learn #3
There is a reason you are supposed to wear a harness and be tied off to the basket...
Aaron Z
Not to say getting thrown 20 feet in the air didn't suck, but I an only imagine the bruises a harness would have left.
   / You would think he would learn #5
Those things have a high and low speed switch which he obviously didn't know about the slow speed. He could have eased if off the slab with no problem. His first experience with the front falling should have given the idiot at least a clue as to what would happen when the back came off with opposite reaction from the front, but in his stupid mind it didn't register. Another thing he could have done was operate it from the ground station although I am not sure that the travel option is available. I know all the boom functions are though. OSHA rules that you must have a safety harness when using those machines also. He would still have been banged up a bit from his stupid act, but the fall would have arrested after only a little less than 6 foot rise (most lanyards are 6 feet long) at which point he would have been whipped back downward, likely banging off the basket a few times. He may have survived with fewer injuries without the safety harness in this case.
I once saw a guy run one of those off into a ditch on one side with over 90 feet of boom out. He was harnessed in but the boom fell across a pipe rack putting a 45 degree bend in it, tossing him out at which point he was hanging in the air about 40-50 feet off the ground. He had some lacerations and bruising but he would surely died if he had been thrown out without the harness.
   / You would think he would learn #6
I think we found the village idiot.
   / You would think he would learn #7
I'll bet he's one of those who sat in the back of the bus and hit his head every time the bus went over a bump.
L2800 w/FEL - 72" Land Pride rake
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
CONTACT INFO (A53084)
