YM2610 or YM2620
   / YM2610 or YM2620 #1
Smoody
Platinum Member
South Carolina
YM226D
Ok, I found 2 yanmars I am interested in, they both are priced within $500 of each...
YM 2610 and YM 2620...
what are the differences in these 2 models?
Only thing I see different is the weight..tractordata.com puts the 2610D at 2712 lbs, a 2610 2WD is not listed??whats the weight on a 2 WD?
The 2620 2WD weighs 3582 lbs,
is this the only difference, other then year manufactured? same engine in both?
which is better?
Also located a 2000D with 800 hrs for $2900, isn't this a newer model? and is there alot of difference in power and size versus the 2 models above?
   / YM2610 or YM2620 #2
I think the YM2610 is a 2 wheel drive and the YM2620D is a 4 wheel drive. Both units use the same 3t84 engine. The YM2620D also came with a 3 point lift cyl., mounted on the right rear side lift arm. The weight difference is in the front axle assembly.
I have really enjoyed my YM2620D. It has done all that I needed to do. Lots of power.
   / YM2610 or YM2620 #3
The Ym2610 comes in both 2WD and 4WD versions. Mine is a 2610D (4X4)and has a 3T80 motor.
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53473)
2012 RAM 5500...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
Scaffolding (A52377)
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
Vibratory roller attachment (A53421)
Vibratory roller...
198367 (A51243)
198367 (A51243)
