Oil & Fuel Ym240 injector washers
   / Ym240 injector washers #1
jbrd
East San Diego County, Ca.
B7800 & Ym240
Any advice on replacing the washer under the injectors? I can see where the white fiber washer goes on top of the upper chamber, but to put the copper washer under the upper chamber I'll need to pull that piece up, how is that done? I'm going by the diagram on Hoyes site where it says " What's under the injector". Thanks, jbrd
   / Ym240 injector washers #2
i thought there were copper under the injectors? I think you may have something else on yours, ill look later at mine but sure there is a copper washer under the injector.
   / Ym240 injector washers #3
I have copper washers under my injectors..
   / Ym240 injector washers #4
Normally, as long as you have not disturbed the lower chambers you can just leave them alone. If you need to replace the copper washers (because of a leak or something) you will usually have to remove the head & press them out.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks for the replies, The way this ym240 is set up under the injectors is a copper washer with the fiber washer inside of it. I thought this one might have been set up wrong. I'll replace them the way they currently are. Thanks again, jbrd
   / Ym240 injector washers #6
look at the diagram there is a fiber washer listed in the parts diagram on the injector, although i have no idea how and where your washers are compared to this diagram.
2007 FELLA SM350 3 PT DISC MOWER (A53472)
2007 FELLA SM350 3...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
