YM240 Diff Lock Repair Question
   / YM240 Diff Lock Repair Question #1
Maynah13
Central Maine
JD 750
I put my YM240 up for sale and discovered that the differential lock is broken. I knew nothing about it, so I never tried to use it. The pedal just stays down all the time, with no spring tension. I can pull the pedal up and down, but it doesn't do anything. Is this a major repair? Seems people want it to work in order to buy it. This was my first tractor and I wasn't savvy enough to know about such things. Also, the dealer didn't mention it (sold "as is" of course). I've since bought all the manuals but the repair procedure isn't mentioned.
   / YM240 Diff Lock Repair Question #2
Could it be something as simple as a broken roll pin between the pedal and shaft? If the shaft moves with the pedal then obviously you would have to dig deeper.
   / YM240 Diff Lock Repair Question #3
There is no spring tension on that pedal. You just push the pedal down & it pushes against a pin that goes into the diff. to enguage the lock.If you pull the pedal all the way up , you can see the pin
Hmmm...I'll take a closer look at the shaft and pin tomorrow.
   / YM240 Diff Lock Repair Question #5
Hold your foot on the pedal to enguage. Take your foot off the pedal & it is suppose to self disenguage
The pedal is laying on the floor, so putting my foot on it isn't going to do anything. If I lift it up with my hand, it falls back down like a dead weight. I'm going to take a better look at it today and see if maybe the pin is broken.
The pin is intact, so I guess it's something internal. The wheels turn independently, so they aren't locked, at least.
I find it odd that there hasn't been more people with this problem, given what I've heard about how easy it is to break this, such as engaging while moving or forcing it to stay engaged while turning.
I read elsewhere that I need to remove the rops and PTO to get to it. Anyone know this for a fact?
   / YM240 Diff Lock Repair Question #8
When I raise my pedal up . It bounces back down against a pin that sticks out just a little.Can you see the pin that the pedal would rest against in the down position ?? Like I said mine isn's spring loaded it just lays there waiting for the foot to press it
   / YM240 Diff Lock Repair Question #9
Could the spring be missing on your 240 ??
   / YM240 Diff Lock Repair Question #10
There is a roll pin, 5m x 40m inside a 8m x 40m that holds the diff fork tight against the spring on the inside. You will have to remove the hyd cyl housing to get to it. Maybe the roll pins are broken. Not a hard job, just time consuming.
Danny
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2016 Freightliner M2 (A53422)
2016 Freightliner...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
1268 (A50490)
1268 (A50490)
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
