YM2310 3PH hydraulic questions.
   / YM2310 3PH hydraulic questions. #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Hi Folks,
I have two manuals for my 2310. One is a very thin operator's manual with about 1/2 of the pages being safety warnings, and the other a service manual that's about 1 1/4 inches thick. The service manual is actually for a YM276 but Hoye Tractor says it is close enough.
The operator's manual says to use the knob under the seat to lock the 3PH in a raised position. The knob must be either wide open or fully closed. Wide open for regular use and fully closed when locking the 3PH. When closed there must be no attempt to raise the 3PH as this will cause damage.
The operator's manual says that next to the knob is a lever that can be used to slow the rate of the 3PH lowering.
The service manual only mentions the knob and this knob is used for both locking the 3PH and for slowing the rate of the 3PH lowering.
It seems like on my YM2310 the lever does indeed change how fast the 3PH lowers but the knob also seems to do this, so why both the lever and the knob? Also, the knob and lever now seem to be stuck so I will need to figure out how to loosen them. Any advice will be appreciated.
Finally, is there a way the slow how fast the 3PH raises? When I move the 3PH lever it rises so fast that it jerks. I cannot get it to rise smoothly. I move the lever in small increments and the 3PH seem to move instantly. I cannot move the lever slowly because it seems to be sticky. I am going to try to figure out how to get it to move more easily. Once again any advice on how to fix this will be greatly appreciated.
Thanks,
Eric
   / YM2310 3PH hydraulic questions. #2
Does your little lever look like mine on the YM2610 or similar?
I have the flower knob turned all the way open and the little lever exactly where the image shows. Otherwise, I too would get the jerking of the 3PT.
At the back of the machine's 3PT is another 'lock' lever. Wherever the 3PT would be sitting, once that lever is pushed down, the 3PT will not move up nor down. I once touched that whilst washing the machine and didn't realize it. Then for 3 days went nuts not knowing why the 3PT wasn't working. hahahaha
Though the lever on my YM2310 looks identical, right down to the plastic covering the roll pin, it is in a different place. If a person were to look directly at the knob under the seat the lever in question is to the left of the knob. I'll try rotating the lever to see if it gets rid of the jerking. That is once I can get the lever to move. I don't understand why the lever and knob are both sticking now because I could turn them both about 9 months ago.
Thanks,
Eric
   / YM2310 3PH hydraulic questions. #4
Thanks,
Eric
Looking at my little lever, it is very clean and where it attaches the brass fitting is clean too. Does yours have any grime on it or in the brass fitting area? Liquid Wrench could help?
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
2000 Genie Man Lift (A50322)
2000 Genie Man...
2017 PETERBILT 587 TANDEM AXLE SLEEPER TRUCK (A51222)
2017 PETERBILT 587...
2024 LandHonor TP2-13-08D Hydraulic Tree Puller Skid Steer Attachment (A49462)
2024 LandHonor...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
