YM220 and cutter
   / YM220 and cutter #1
Mikeeeeeeeeee
I just bought a YM220d with a 4' King Cutter. 834 hours on the meter and everything works except the lights. (no problem to fix)
I have some things I want to do right away.
1. Set the rear wheels outboard to give me a little more stability.
2. get the lights going
3.Find out the part numbers on all the filters.
4. get reccomendations on oil and fluids
5. keep my 5 acre wooded lot in good condition.
Any advice is appreciated.
Mike
   / YM220 and cutter #2
welcome:thumbsup: Not sure about your air,fuel,oil filter #'s. Your fuel filter bowl may or may not be original. If it's been replaced, you may have to find a filter that will fit or replace bowl with original type...you can buy filters from Fredricks or Hoye & have them shipped it you choose. Oil will be 15w40 diesel rated oil. Hyd fluid will be JD303 or any brand that meets JD303 specs. Front gear oil will be 75-80 w 90
   / YM220 and cutter #3
Hi 'Mikeeeeeeeeee',
Welcome to the forum... :)
Loosen Lug Bolts a quarter turn first.
Place Jack Stands or Blocks under the rear axle near each wheel. Because of the front axle pivot and it is necessary to remove both rear wheels at the same time.
Swap wheels.
Yanmar Tractor Parts: Head Light Bulbs
Yanmar Tractor Parts: FILTERS
What 'kenmac' said...
What may help is undergrowth control. A sprayer system and Glyphosate mixed thin (about 1/2 percent) and spray generously, more water works best in the heat. 2 1/2 gallons will make 500 plus gallons of spray mix.
Drexel Imitator Plus Glyphosate 2.5 Gallon Jug w/ 15% Surfactant America's Farm & Home Store
Mike
Yanmar Tractor Parts: YM220_220D
Hope it helped!
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2015 International 4400 Cab & Chassis (A47384)
2015 International...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
