Ym2000 rpm speed for finish mower
   / Ym2000 rpm speed for finish mower #1
dirtracer7x
Fayetteville, AR
Ym2000
Hello all
I have had this tractor for 6months and finally got a finish mower for my 3 acres.
What gear and rpm would be recommend? Also it does not have the over run clutch on the PTO. Do I need this? Are there different pto gears also?
Any info will help.
Thank you
   / Ym2000 rpm speed for finish mower #2
Any implement made for the American market (and the small tractors we are talking about here) is designed for 540 rpm pto speed. (and unsafe to spin the implement much faster than that).
On your YM2000 to get 540 rpm pto output, shift the pto lever to the slowest position, that's 'standard 540'. 540 rpm output is attained at about 2200 rpm engine speed. If this mower doesn't bog down the engine, you might be able to run at lower engine speed and the next higher pto speed to again, have 540 rpm coming out of the pto shaft.
The higher speeds found in our ptos were intended for the implements they use in Japan, not applicable here.
As for ground speed I use my rotary mower in high range 3rd gear, higher or lower gear occasionally. You want a more uniform cut with a finish mower so this might be too fast to get a smooth cut on uneven ground.
Overrun clutch? The inertia of a spinning heavy implement can push you right into the side of a barn or over a dropoff before you can get the pto out of gear. Experiment and see if this lighter finish mower keeps pushing that hard after you put in the clutch and press the brakes. (Pushing in the clutch does not disconnect the mower from the drive train, there's still a direct mechanical connection through the gearbox from mower to the tractor's wheels until you shift the pto lever out of gear).
   / Ym2000 rpm speed for finish mower #3
Your pto has 3 speeds, 588,730,1260 rpm. These speeds are achieved with engine speed around 2200rpm. Your finish mower will be rated for 540rpm maximum. Anything over that becomes a safety issue. For heavy mowing you would want to be in the first (lowest pto speed) with engine rpm around 2200. Transmission speed adjusted to conditions. Listen to your engine and mower, you can tell by the cut and pull whether you need to slow or not. In light mowing you could probably use the second pto speed but slow engine rpm so pto speed will not exceed 540 rpm. You do not want to lug your engine down where you are getting constant black smoke.
Although finish mowers do not have the flywheel effect of a rough cut rotary mower they will still have some push on your tractor when you push the clutch in. I would recommend you get an over run clutch.
Woops, California got in before me, and always with good advice.
I have a left rear axle seal leaking, what type of fluid, is there a dip stick, and how hard to change the seal?
I have a race car so tools and know-how won't be a problem but do I need any special tools?
   / Ym2000 rpm speed for finish mower #6
Thanks guys. Getting great info.
Is there a place to get used parts. I was looking today and radiator could use replacement.
   / Ym2000 rpm speed for finish mower #9
Type in "Yanmar used tractor parts" on Google. Not sure a used radiator would be wise. Could yours be taken to a shop for cleaning?
The battery had hit it and all the fins on the bottom half are smashed.
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2024 Bintelli 4PR Activ-EV Pulse (A50324)
2024 Bintelli 4PR...
