YM2000 Hydraulic Fluid - Capacity?
   / YM2000 Hydraulic Fluid - Capacity? #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
Will one 5 gallon pail of 'JD 303' be enough for my YM240 (YM2000 equivalent) and the big Great Bend loader on it? The manual says 4 gallons capacity for the tractor alone without a loader.
If not, what next - buy another pail and use part of it, look for gallons, or re-use a couple of quarts of the old fluid to top it up? (The old fluid looks clean.) I've never seen this fluid sold in quantities other than 5 gallon pails.
Also, since the existing fluid looks good and the system works well, what are the chances of needing a new strainer?
   / YM2000 Hydraulic Fluid - Capacity? #2
I would remove the screen and check it, and clean while the transmission is drained. I would not use the old oil.
Danny
   / YM2000 Hydraulic Fluid - Capacity? #3
I don't have a loader, but I would not be afraid to re-use a gallon or so of old oil, as long as it looks good, and especially after letting it sit and settle out any impurities. (I understand the loader needs a couple of gallons). I would only replace the strainer if it shows signs of deterioration, (maybe order in advance and keep on hand, since, if it is bad, you are stuck).
And the answer is ...
4 gallons, same as without a loader.
It seems intutive now, I didn't drain the hydraulic cylinders, so the loader system didn't require any extra fluid.
Here are a couple of tips for anyone who has to do this project - these made it easy to pour directly from the 5 gallon bucket:
For a high capacity funnel I looked in the recycle bin and found an empty bleach bottle with threads the same diameter as the transmission fill hole. After cutting off the bottom and rinsing it, this screwed in rigidly into the transmission filler hole. This funnel would take fluid faster than I could pour it so I never had to stop.
Also, removing the seat made plenty of room to work. This is simple, there's only a spring clip to remove, then slide out the long hinge pin under the front of the seat.
Hopefully this information will be useful to someone in the future. I have found lots of good advice here and now it's good to be able to share some.
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
UNUSED X-STAR 250 GALLON FUEL TANK (A51247)
UNUSED X-STAR 250...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
