YM1820D dash not working.
   / YM1820D dash not working. #1
dgarrett
Kitsap WA
Kabota B2320 Narrow
The fuel gauge and alternator displays do not work. When I press the test button they do not light up but the other two on the right side do light up. Is there a fuse somewhere for each display?
   / YM1820D dash not working. #2
I believe all your displays are on a 5 amp fuse. I wouldn't think your fuel gage would light up when pressing test button. Does the fuel gage work? I would look for a bad bulb on the alternator display, if not, then a bad connection.
   / YM1820D dash not working. #3
The fuse box is in front of the clutch pedal, under the red panel.
   / YM1820D dash not working. #4
I have a 2310 that the same thing is going on i have checked the fuse and have power in and power out
   / YM1820D dash not working. #5
There are 4 lights in a square. Right side is oil pressure and charging light. Left side is battery level and overflow level. With the key on, engine off and button pressed they should all come on.
   / YM1820D dash not working. #6
Don't know about the fuel gauge, but when the alt. regulator died on my 2301, the alt light would not work when the test button was pushed. I spent a lot of time tracing it out before I finally opened up the reg and found it fried.
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
JMR stump/trenching bucket (A53421)
JMR...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
2023 Country Clipper Boulevard 54in Zero Turn Mower (A52377)
2023 Country...
