YM1700 Temp
   / YM1700 Temp #1
cigardave007
Yanmar YM1700
Greetings All.
Recently purchase a YM1700. I haven't really done any work with it. Mainly just driving around the place (next to the highest gear/2400rpm). The temp gauge (Sunpro add-on)after about 20-25 mins shows about 208-210. I flushed and cleaned the radiator, filled with water(no anti-freeze) and added about 5 oz of water wetter. The radiator cap is new 8lbs. Still the temp is about the same.
I'm just worried that when I get a finishing mower I will have a serious temp problem.
Also Wide open she will only run about 2400 rpm. Is this normal??
   / YM1700 Temp #2
Everything sounds normal to me, except I believe you need a 13# cap.
   / YM1700 Temp #3
Hi Cigardave,
I have a YM1700 and 2400 rpm is correct. Your temperature measurements under no load sound a little high, but not out of question. Mine would run around 190 under no load and go up as high 220-230 while mowing with a 5' finsih mower. With a 5' finish mower, you may have to drop down to 6th gear and drop the RPMs a bit (2000-2200). It all depends on the load.
If you do a search for Operating Temp (all dates), you should find a wealth of knowledge.
Allen
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
2016 Komatsu D61PX-24 Crawler Dozer (A51573)
2016 Komatsu...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
FRONTIER LP2196 LOT IDENTIFIER 101 (A53084)
FRONTIER LP2196...
