YM1500 Axle Seal Leaking
   / YM1500 Axle Seal Leaking #1
mjdupre
Chicago(work)/Kentucky(play)
Yanmar 1500 (Red)
My new (to me) YM1500 appears to have an axle seal leaking.
There is a puddle of what looks like trans or hydraulic fluid by the right tire.
Just curious if anyone has had any experience in changing one of these out on a 1500, is this a one day job or am I about to open a can of worms ?
   / YM1500 Axle Seal Leaking #2
Replacing the actual rear axle seal is not a bad job. Just pull the hub (sometimes VERY stuck though), & remove the 4 bolt housing that holds the seal.
The bad part is that oil leaking out around your rear axle seal means that you have oil leaking from somewhere else- either behind the brake drum or the internal axle seal has failed. Those are much more difficult to replace.
You can see in this diagram (for a 1500 red, 1500 green will be slightly different but you get the idea)--
REAR_AXLE_INTERNAL: Yanmar Tractor Parts
#36 holds the oil in the transmission. #58 (the outer axle seal) should only be holding water & dirt away from the bearing. The area between the 2 seals (the brake housing) should be dry.
Aaron
Parts@HoyeTractor.com
(940)592-0181
Thanks Aaron, That's what I was afraid of.
I'm contemplating doing it myself, with the help of a auto mechanic friend.
I was looking at a post in this forum by Eddie: Winter Repairs, it's not clear what model he's working on there. But it sounds like the tricky bit is getting the PTO cluster back in place.
Does the service manual cover this pretty well ?
Any tips appreciated, I'm planning on bringing the tractor home in a couple of weeks to give this a shot, unless someone talks me out of it.
Mike
   / YM1500 Axle Seal Leaking #4
Mike
If you have a red YM1500 remove the wheel and take the bolt out of the hub and remove hub from axle. You will need a hub puller and most of the time you will have to heat the hub with a torch while pulling the hub off. Be careful not to damage the threads in the end of the axle with the puller. After you remove the hub remove the 4 bolts from the seal case and pull the seal case off, check the seal collar for grooves, I always replace the collar even if there are no grooves, replace seal and reinstall. It is a good idea to remove the hydraulic screen in the transmission and clean it while you have the oil already drained.
Danny
That's fine for the outer seal, but from the previous post it sounds like the inner seal should be replaced as well.
   / YM1500 Axle Seal Leaking #7
I had to replace an outer bearing on mine several years ago. That entailed removing the axle (which does not involve the PTO assembly, BTW). I replaced the inner seal and seal collar as a precaution. As I recall, the seal was relatively hard to find and a bit expensive. I wonder if it would have been practical to find a replacement for the inner bearing that was sealed on only one side?
A related question--Since the new outer bearing was sealed, was the new outer seal required?
Reb,
Are you saying that you don't have to pull the axle on the 1500 to get to the inner seals ?
   / YM1500 Axle Seal Leaking #9
No. You have to pull the axle, but the first step, after draining the transmission, is to remove the plate on the bottom of the transmission housing (the drawbar is attached to it). Then reach inside to loosen the bolt holding the axle to a gear. You also have to remove the axle housing to get access to the seal.
A parts manual is invaluable in seeing how it goes together.
Reb,
Thanks for the info.
If I understand you correctly, you're saying that you can access the axle retaining bolt and clip by removing the case bottom and thus avoid removing the PTO transmission?
When you mention "remove the axle housing" are you referring to the entire axle cases (16/17) or just the bearing carriers (33/35) in the REAR_AXLE_CASE
diagram? (Hopefully just the carriers)
I purchased a repair manual but I was disappointed with the quality of the pictures and the lack of information on the rear axle area. I probably should have just gone with the parts manual.
I plan to bring the tractor home next weekend, it's at my summer place, and we'll give it a shot.
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
