YM140-7 Belly mower question
   / YM140-7 Belly mower question #1
Neat 1500
Platinum Member
Queensland,Australia
Only a YM14 MkII
I have the Euro YM14 with a Bar style blade conversion using standard push mower blades bolted to the centres of an old set of bar blades which works a treat, and is cheap to replace blades but if I mow anything other than clean twig free grass it eats through them. I wanted to go back to bar style blades but I cant really find anything that suits but thats not the main problem. The biggy is everything has a rear or right discharge which makes the fold on the blades wrong for me as I need left discharge. What I have done in the past is cut the lip off the blades and weld them on to suit left which works OK. I didn't want to do this with new bar blades to try and keep strength in them but it's proving to be a little difficult. What are other owners using and where are you getting them from? I think it's a YCM60 deck too.
Edit: I looked in the US and they can be had there but not here in Australia, I may have to buy in the US.
I took my second option for now and found one manufacturer with blades for left throw which is Greenfields. They basically bolted straight on but are separate blades and not a bar but works well cutting nice and close to the ground and are much more sturdy than push mower blades. Will keep searching I guess.
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
