ym135 loader
   / ym135 loader #1
Chuk
western PA
YM135
Does anyone make a loader for my YM135? I think it's comparable to the grey mkt. 1100. I'm pretty sure I've seen them somewhere before but not sure where.
   / ym135 loader #2
You mean one that bolts on? Not that I know of. I've seen Yanmar brand loaders on 155's, but not a 135. Koyker doesn't make one either. Right now I'm adapting a Kwick-way loader to my 1110. This is a pretty common loaders for the Gravelys, Simplicities and older John Deeres. It's about the right size. Johnson is another manufacturer that made a tiny loader that would fit your tractor. No matter what, you will be fabricating the brackets to mount the loader.
   / ym135 loader
I wouldn't need one that would be a bolt on, but anything that would be sized right would be a step up from having to fab the whole thing. I thought the 155 was basically the same tractor as mine, just larger tires and bigger sleeves in the block. My manual shows the same transmission, rearend, crankshaft dimensions, etc. But I've never compared the two side by side.
   / ym135 loader #4
This is a Johnson loader. 7739157943 Your tractor is pretty comparable to this John Deere, so you can see that the loader is a pretty good match. The kwick-ways are also pretty close in size. I do know of a Johnson loader that is for sale and would be the correct one for your tractor. The hoses are cracked, but it includes the pump and control valve and has a convertable tine bucket. $1k asking.
   / ym135 loader
I don't see the johnson loader, mabye it's my computer. A used one for around a grand sounds good to me... but I probably won't find one when I have the money. Where are you located cord?
   / ym135 loader #6
Actually, the number is a ebay auction number. Copy and past it into the search window on ebay and it'll take you to a auction. The auction is for a tractor and loader, but it'll get an idea of what you are looking for. I'm located in Wisconsin. The loader is in North central Illinois. When it comes time, I can show you where to shop for freight.
   / ym135 loader
Thanks cord, I found it. Looks like a nice unit. I'm gonna start looking locally to see if I can find something. I appreciate the help and will let you know if I need something.
   / ym135 loader #8
I have a Johnson loader off of a large garden tractor that would work on a YM1100. it comes with a hydraulic pump & control valve. the bucket is convertable, either tine or regular bucket.
   / ym135 loader
Thanks leonard, I'll send you an e-mail .
JOHN DEERE 1050 TRACTOR (A51247)
JOHN DEERE 1050...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A53426)
2019 HINO 195 16...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
