YM1110D Won't Charge
   / YM1110D Won't Charge #1
OhioBruce
Yanmar 1110D
My 1110d won't charge. With the engine running I unplugged the alternator (generator?) and used a multimeter to test for voltage and it read zero.
I removed the alternator (generator?) and see that it is a permanent magnet type.
I've done a little research and I'm confused about if it is an alternator, generator, dynamo, and how to test it and the voltage regulator.
If anyone could give me some advice on how to proceed I'd appreciate it.
Thanks,
Bruce
   / YM1110D Won't Charge #2
I have no idea what is on the 1110. Sorry :confused3: If is is a dynamo you would test touching the two outlet terminals on the dynamo with tester set on ac volts. Should have 13+ ac volts depending on speed.
   / YM1110D Won't Charge #3
Take the alternator and voltage regulator to an alternator repair shop. They can tell you what you've got and what it should be doing. Parts should be less expensive than a tractor repair shop.
Good idea. I removed the voltage regulator tonight and will take them both to the repair shop this week. Thanks!
   / YM1110D Won't Charge #5
Thanks,
Bruce
I can help you with it if you would prefer to learn about them or do it yourself. Certainly there isn't anything wrong with just taking it to an automotive electrical shop. But sometimes it is fun to know a bit more. And you did ask some good questions.
BTW, the most common problem with an alternator, AC generator, or magneto (all sort of the same thing) is not the magnets or the coils inside, it is usually that the diodes on the diode plate on the back of the AC generator have failed. You might try your multimeter on the AC setting and see if spinning the alternator on the tractor gives you about 20 volts AC instead of any DC voltage. If so, it's one or more diodes that need replacement. They just solder in.
I'll answer some of your questions for the future
Is it an alternator or a generator or a dynamo? Well, it's any and all of those. They all do the same thing. Anything that generates electricity by moving a magnet a past a coil is a generator of some kind. And more specifically, it is an AC generator. No matter how, all generators make AC voltage by moving a magnet by a coil, and each one has a different way to convert that AC voltage into a DC voltage that is more easily regulated and can be used to charge a lead/acid battery. The different names actually refer to how each one converts the AC voltage into a DC voltage.
The traditional automotive GENERATOR from about 1920 up till the mid 1960's used carbon brushes running on a divided plate called a "commutator" to mechanically convert the AC it made into a DC that could be regulated and used for batterys and lights. Magnets at the time were weak, so instead of magnets, the GENERATORS used large "field coils" to make a magnetic field that their other coils moved past. GENERATORS were big and heavy and complicated....but remarkably reliable.
Later on, in the mid 1960s, two things happened: Semiconducting diodes were invented and could be used to convert AC into DC. These diodes did away with the need for brushes and commutators.
At about the same time, the first of the modern high powered synthetic magnets "ALNICO" was invented. ALNICO magnets did away with the need for field coils.
As a result, the ALTERNATOR was born.
Note that you still have to have a motor to move the coils & magnets past one another, and there are some times when the motor is built right into the GENERATOR or ALTERNATOR. When that happens, the combination is called a DYNAMO.
Household backup generators and portable welding generators are examples of DYNAMOs in use today. Just to confuse things, they are both called generators instead of their proper name which is a dynamo. And to confuse things farther, they are more closely related to motors plus alternators than they are to the ancient motors plus generators of the early 1900s....But if you put a motor and a generator together you have a DYNAMO.
The whole basis of all of this is the simple fact that anytime you move a magnet past a coil or a coil past a magnet you generate a voltage in the coil. The voltage goes up - call it positive - as the coil approaches the magnet and the voltage goes in the other direction - negative or down - as the coil moves past the magnet and away. Voltages that goes up and down between positive and negative that way are called alternating currents. The voltage goes up the faster the magnet and coil move past each other.
Yes, you can move the magnet past the coil if you had rather. And in your Yanmar's AC generator that is how it is done. Usually its a set of six magnets and six coils. Six of each (the number doesn't matter) just to smooth things out. And by moving the magnets and letting the coils stay stationary, you don't have a problem with how to keep the output wires from winding up. If the coils are stationary and the magnets are moving, the wires from those coils are also stationary and that turns out to be a big advantage. If you end up designing it the other way around so that the coils move and the magnets are stationary then you have to interrupt the leads from the coils by connecting them to brushes contacting a rotating ring.... ugh. Better to just move the magnets.
There is probably no need to take your Yanmar alternator apart. All you would see inside is a group of coils all bolted to the backing plate and connected in series, and some magnets cast into the rotor so cleverly you probably cannot even see them. Neither one is likely to go wrong. If you can get to the leads coming from the coils and measure the output there without them being connected to the diodes then you will probably see about 20 volts AC.
If you measure it after the diodes are involved it will be about 12 to 15 volts DC depending on RPM.
You can test the diodes with your multimeter using the ohm (continuity) setting, but you have to disconnect them from the circuit to do so. One side of the diode is screwed to the backing plate, and the other has a wire soldered to it. Unsolder the wire - carefully & quickly because diodes are a little bit sensitive to heat - and the diode should show continuity measured between the free end of the diode and the base plate with the test leads in one polarity. And it should show no continuity with the test leads reversed. Anything else means replace that diode.
If the AC generator (alternator) doesn't show DC output when it is spun, chances are good that bad diodes are the problem. Especially so if it does show AC output....
If the multimeter does show output from the alternator, then the problem is in either the voltage regultor. the ignition switch, or the battery itself. We can go as deep into those as you would like, but this is a good place to quit for now and see if anyone has a question.
enjoy,
rScotty
rScotty - Thanks for all of that info! I do like to learn and do everything myself if at all possible. I'll take a look and see if I can find the diodes and test them with my multimeter.
Thanks!
Bruce
Well, I didn't see anything that was easily desoldered so i just took it to the alternator shop. They tested it and told me it was shot and they could not repair it. They could not test the voltage regulator.
I took it to a second shop and they told me that they were swamped with work and couldn't test it, but if it was bad, they couldn't repair it anyway. They also told me that they couldn't test the voltage regulator and I should try replacing it first to see if that was the problem.
Here is a pic of the alternator. Are those cylindrical things with the wires soldered the diodes?
   / YM1110D Won't Charge #8
Yes they are the diodes.
BTW, you can test it for yourself if you want....it's only a 50% test, but will tell something.
1. Look at the front of the engine and figure out which way the alternator should spin.
2. bolt the pulley or something similar to the front of the alternator.
3. Hook up your multimeter leads to those two wire coming out from the coils - these are the black and white? wires at the top of the picture. Set the multimeter to 50 or 100 volts AC.
4. spin the alternator. The easy way is to just hold it up against a rotating wire brush. You might have that in the shop or have one you can chuck into a drill...or whatever.
See what you get.
We can test the diodes. The coils can be thought of as a short circuit. In fact you should test for continuity between the two coil wires before you do the test above. There should be continuity between the upper two connections where you measure the AC voltage. Continuity and AC voltage when it is spun tells you the coils are good. If so, we are going to win....well, we win anyway, because we can always re-wind the coils...but it's a pain.
If the coils are putting out, we then get into how to test the diodes. BTW, this is the simplest circuit ever. We may just leave them there and buy (or make) a simple diode plate that is mounted outboard of the alternator.
rScotty
BTW, I don't think much of your electrical shop guys.
Yes, I didn't think much of those guys either. I didn't believe it couldn't be fixed so I stopped at the second shop - and he was worse.
Anyway, I stripped some insulation off the wires and connected test leads like this:
1. I have continuity.
2. When I spun the alternator by hand I got 5 volts. I pressed it against the wire brush on my bench grinder and it quickly went up 15 volts and I stopped when it hit 20 volts as it gained speed.
I looked carefully at the diodes and can see evidence of a previous repair and one solder joint looks marginal. I like the idea of making a separate external diode plate. I've built speakers so I have some rudimentary fabrication/electronic/soldering skills. Mostly I can follow directions. Lol.
I really, really appreciate your help!
Bruce
   / YM1110D Won't Charge #10
That's great! Typical alternator....good coils; probably a bad diode.
We could have wound the coils if we needed to, but nice not to have to.
A diode is a one way valve for electricity. To test a diode, it is necessary to disconnect any diode from the rest of the circuit. Then you can test the diode with your continuity checker. Place one lead on the obvious diode terminal and the other lead to either the other diode terminal - or if it doesn't have but one obvious terminal the other terminal is the diode case itself which is being used as a common case or body ground. A diode will always have two "terminals", although one "terminal" may be the diode case itself
A good diode will show continuity (zero the meter & record the ohms) with the leads connected to the two terminals of the diode one way, and then when you reverse the leads it will show no continuity. That is all there is to the test. The diode acts this way because the diode is being a one way valve relative to the polarity of the battery that is in the multimeter.
If you make chart or some sort of list of your measurements on each diode that will help us both.
All 4 diodes are supposed to be electrically the same. Sometimes they are physically the same, but not always. Looking at that alternator picture, I wonder you took out those two phillips screws and looked beneath you would see that all 4 diodes are the same except that two of the four are mounted upside down? It would make sense go take those phillips screws out and check that.
If you do so, make up a sketch of how the wires under the plate are connected.
If we do decide to make up a diode plate, we will use any regular automotive diodes and wire them so that polarity-wise so that we can rectify both sides of the AC wave that they are seeing. That means that electrically speaking, you have two diodes connected one way and two the other way around. But we can get into that after we know the status of the diodes you have.
Yes, either way we do it testing diodes does require either unsoldering the wires to the diodes or somehow isolating each one to test it individually. We don't have to remove them from the diode plate, but at least one of the diode terminals that has the wire going to it has to be disconnected. One way to avoid unsoldering is to clip the wires between the diodes at the midpoint. That way we can then butt joint them with a short jumper later. That avoid heating the diodes up directly but is sort of a cludge fix. If you are confident with your soldering skills just unsolder the wire.
The diodes are sensitive to heat, but they aren't terribly so. After all, look where they live.
glad you are doing this, it's fun even if we do end up getting a rebuilt alt. from somewhere.
rScotty
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
