YM 2610 filter cross ref.?
   / YM 2610 filter cross ref.? #1
mbueker
Arkansas
ym2610
Can anyone tell the wix or other brands of filters for this tractor oil, air, fuel? All the part stores have in their books are us tractors. not much help.
   / YM 2610 filter cross ref.? #2
I posted a pretty good cross ref a couple of months ago, for oil filters.
My 2610D is almost identical to the JD850 US tractor for the motor(I say almost, but in fact the only thing I have found that is different is the thermostart bowl is injector fed on the 850 and mine is hand filled) . The rest of the tractor is almost identical to the JD950, with exception to the powershift transmission. I would bet that if you used those to cross for air and fuel you would be safe.
http://www.tractorbynet.com/forums/yanmar/104883-2610d-oil-filters.html
   / YM 2610 filter cross ref.? #3
mbueker, Welcome to TBN. I had a YM2610 a couple of years ago and contacted Hoydt's Tractor Parts, out of Texas for everything I needed for mine. I know alittle research on TBN will get you their contact info. Best of luck to you. I loved mine and really didn't want to sell it but, I needed more horsepower (and the AC isn't bad either on my JD3720).
   / YM 2610 filter cross ref.? #4
I have to agree!! Hoyles has all the stuff, that is where I got mine. Just a note here. When I got my tractor the 1st thing I did was change filters and oils.
Noticed that the fuel filter bowl did not have a spring pushing up on the fuel filter. Check yours to make sure it has one. They can get lost easily and if filter pops off the upper portion of the filter housing you will get unfiltered fuel to pump and injectors. I ordered replacement spring from JD (for a JD850)at $0.72 each.
   / YM 2610 filter cross ref.? #5
Hoyles.... Hoydt's...
We should have picked an easier name :D
The new style bowls do not require a spring. They have a plastic tab that keeps the filter where it belongs. I do agree that the old style needs them though.
Aaron
HOYE Tractor Parts
Parts@HoyeTractor.com
(940)592-0181
Thanks for all the help I have bought some items from Hoye already they have alot of items
17101 (A53421)
17101 (A53421)
AIRMAN PDS 100S COMPRESSOR (A53843)
AIRMAN PDS 100S...
2025 380 Mini Track Loader Stand-On Skid Steer (A53421)
2025 380 Mini...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
