ym 240 battery keeps draining
   / ym 240 battery keeps draining #1
bassfishrman
Alabama
YM 240
My battery on my ym240 will not stay charged. It is only 1 yr old and I had it checked today by Autozone. They said the battery is fine.
I can charge it overnight and it'll crank fine the next morning, but if i let it sit for 2 or 3 days, it will barely turn the engine over. The guy at autozone said something is draining it when not in use and I should unhook the negative cable to keep it from draining. First of all, I don't want to have to unhook the cable everytime i get off the tractor, and second of all, I would rather find out what is draining the battery. I always take the key out,, so I know that I am not leaving the key in the on position.
Any suggestions on what could be causing the battery to drain would be appreciated.
   / ym 240 battery keeps draining #2
If I may make a suggestion? See (first) if your charging system is working. If the battery is charged I would check the input DC voltage with VOM from you battery leads while the tractor is running slightly above idle. If you get 13+volts than your charging system is good, if not then I would start with all the heavy connections and grounds. It could be your voltage regulator/current limiter if nothing else works...
Hope this helps.
Mark
   / ym 240 battery keeps draining #3
I think the only way your going to find the source of the problem is to get a VOM out and do some detective work.
I think the first thing I'd check is to see if it is possible one or more of the rectifiers in the VR have failed and are permitting current leakage. One way to test is to put the VOM on the battery with engine running above idle, check voltage D.C. (you should see close to 14V) and then would do same with meter set on A.C. If you see any voltage on A.C. setting, that would be a good indicator a rectifier is shot.
I just checked the voltage with a meter.
With engine off, the battery is showing 12.38 volts
With engine slightly above idle speed it is showing 12.36 volts
Can I assume my charging system isn't working properly?
   / ym 240 battery keeps draining #5
Yep, afraid so. And like Mickey said, if your VOM (set on AC) indicates any AC bleed than your Voltage regulator is bad.
Mark
   / ym 240 battery keeps draining #6
Hate to sound silly, but is you fan belt on, and tight?
ac voltage registers 30 volts.....must be voltage regulator
thanks for the tips guys!
can anybody tell me where the voltage regulator is located on my ym240?
   / ym 240 battery keeps draining #8
I suspect it is in the same place as my 1700. under the dash mounted on what would be the firewall on a car. A square black box about 3" X 4". You can follow the wires coming off the altenator to find it if it is different
   / ym 240 battery keeps draining #9
</font><font color="blue" class="small">( I just checked the voltage with a meter.
With engine slightly above idle speed it is showing 12.36 volts )</font>
A fully charged 12v lead acid battery will read 12.7v after it has set about 4-6 hrs with no current flow in either direction.
Either your VR is shot or there is a bad wire someplace. I would spend a little time looking for a bad wire before replacing the VR. The place to begin is at the connector at the VR. If it's a bad connection or wire, it will still be there after the VR is replaced. Better to know beforehand.
   / ym 240 battery keeps draining #10
take a half an hour & trace all the wires specially from the rear lights forward looking for bare wires worn plastic ect.
Also check under the dash for mice pellets & nests, mice love to chew wires in the winter time
I find that usually thats where my problem lays half the time.
23169 (A50324)
23169 (A50324)
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2013 Kubota F2680 (A50123)
2013 Kubota F2680...
2010 Ford F-750 Stellar 10621 10,000LB Crane Mechanics Truck (A51692)
2010 Ford F-750...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
