YM 2210D - Leaking front spindle gasket
   / YM 2210D - Leaking front spindle gasket #1
wfreebie
Bastrop, LA
YM 2210D
I have a leak at the top of the front spindle housing plate. Not a master mechanic, but it looks like it should be fairly simple(?). Not sure what the drive shaft is going to do when I remove the plate bolts. Iinput? Advice? Thanks much!
Thanks winston1. I think the gasket I'm wanting to replace is #33 in your YM 4WD EXTERNAL link.
   / YM 2210D - Leaking front spindle gasket #4
If that is the gasket all you have to do is remove the bolts holding that cover, pull in off, spindle and all will come out with it, clean surfaces and put a new gasket on. I would be sure to clean everything real good and assure that is where the leak is at. That seems an unusual place for a leak to occur. Not saying it isn't leaking there, just saying make sure before proceeding.
Thanks for the iinput. I will be sure to isolate the leak first. It looks like it's coming from the top of the plate. But, it's possible that it's coming from up above. Thanks again.
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51247)
UNUSED INDUSTRIAS...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
FRONTIER AH11G LOT IDENTIFIER 100 (A53084)
FRONTIER AH11G LOT...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
