YM 2200 filters and running hot
   / YM 2200 filters and running hot #1
jbone108
can any one help with some NAPA filter numbers for my ym2200. also the tractor will run hot after 30-45 minutes of use any ideas radaitor fluid is dirty going to flush. water pump seems to be fine water is moving anyway. do tractors have thermostats? thanks in advance for the help.
   / YM 2200 filters and running hot #2
My 2200 runs a tad under 80 C when the radiator fins have been cleaned on the outside, a tad over 80 C when they start getting dirty. Have to blow or wash them out every couple of hours while mowing weeds in dry weather. No thermostat in this model. I use 25 percent antifreeze and clean water in radiator. Works fine in our 90 F plus weather.
   / YM 2200 filters and running hot #3
No info on NAPA filters for the 2200, but maybe this will help. There is no air filter element because it uses an oil bath filter. There is no hydraulic filter element, just a mesh screen filter that you clean and put back in. I use Yanmar fuel filters, but had to order a new fuel bowl because the one that came with the tractor was smaller than the original. And I use a John Deere compact tractor oil filter. I can provide part numbers for both filters if you want them.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
Kubota ZG327 (A50121)
