Hi All, I'm doing a complete overhaul on my YM200. I have the engine cleaned , ready for new cylinders,my question is ,the liners came with two o-rings for the bottom of the cylinders,but what seals the top? Should I use a sealer or does the headgasket take care of sealing the top of the cyl. liner? Should I use any kind of sealer on the headgasket? I also need to know the torque specs.for the rod,main bearings,and head.The rod bearings broke @ 45lbs, the main bearings broke@125lbs,however I think that would be too much.This is my first deisel eng.rebuild,so I realy need some help. You guy's are great,and I thank you. Jim
