YM 2000 will not start
   / YM 2000 will not start #1
JRB
East Tennessee
Yanmar YM2000
I turned off my YM2000 and about 2 minutes later it would not start (I had been using it for an hour or more). It appears the key switch has gone bad. Has anyone had this problem before? How is the best way to make sure it is the key switch and where do I buy a new switch? I am located in East Tennessee. Thanks!
   / YM 2000 will not start #2
When you say it won't start, are you meaning it won't crank over? If so, I would jump the starter at the solenoid and see if she cranks. If it does then you can look at the switch and/or wiring for the problem.
It will not do any thing. The lights will not come on, it will not click the starter, the charge light nor the temp. light will not come on when the key is turned on. The battery which is new checks ok (12 + volts). In the off position I have 12 + volts at one terminal of the switch. The fuses look ok and I checked continuity of them and they seem ok. It acts as though the switch does not do anything.
   / YM 2000 will not start #4
That is sounding like key switch problems.
Locate the ignition wire ( which powers your solenoid) on the key switch, and jump power ( you said one terminal did have power ), and check there.. if it cranks over, the rest of the wiring in line is good.
You can either get a replacement from one of the dealers here, and if you have thermostart, I would, otherwise, there are many generic key switches available that will do what you need..
Soundguy
   / YM 2000 will not start #5
JRB,
Sounds like the switch is not feeding power to the fuse block or start circuit. Do all fuses have power on both sides with the key on?
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
2022 MAXEY TRAILER MFG 18 TANDEM AXLE CAR HAULER TRAILER (A52472)
2022 MAXEY TRAILER...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
