YM 2000 Clutch travel....
   / YM 2000 Clutch travel.... #1
Coyote
North Carolina
Yanmar 2000B & Skat Trak 1300D skid steer
My clutch has started going almost all the way down with no resistance and only engages in the last inch or two of travel before it bottoms out for shifting gears. What is going bad here?
   / YM 2000 Clutch travel.... #2
Try looking at www.hoyetractor.com On the left side there is a section that say Tech Info, etc. 2nd item there lists Clutch replacement. That might help.
Jerry
YM2000BD, Koyker120 FEL
   / YM 2000 Clutch travel.... #3
Have you eliminated loose adjustment linkage?
I have been doing that as the pedal kept going down. Does this confirm I need a new clutch?
   / YM 2000 Clutch travel.... #5
Yep. /forums/images/graemlins/frown.gif
   / YM 2000 Clutch travel.... #6
My guess is not so much the clutch disk itself but something is failing with either the linkage or pressure plate. Clutch disk wear should only have min impact on free play of clutch peddle.
   / YM 2000 Clutch travel.... #7
I agree, as the clutch disk is barely .375" (and 3/8" travel is minimal) it is usually and indication of weak pressure plate fingers..but when you have to split the tractor it's best to change it all.
Free Beer!! Tractor splitting party at my place! BYOT (bring your own tools) !!
   / YM 2000 Clutch travel.... #9
OK...... I'm in ! But i must warn you, the last time i was involved in a tractor splitting...... the old WainRoy was never the same !!! /forums/images/graemlins/cool.gif
   / YM 2000 Clutch travel.... #10
Isn't there a couple of springs that attatch to the fork that holds the throw out bearing ? Don't these springs put resistance or pull the clutch pedal back up after it's depressed & take your foot off the pedal ? I had these springs break once on a ferguson which felt like the clutch was gone . You would still have to split the tractor though . /forums/images/graemlins/frown.gif
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
2001 International 4700 Dump Truck (A51691)
2001 International...
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
