Mowing YM 147 alternator and mower questions
   / YM 147 alternator and mower questions #1
Chillimau
Prairie View, OK
Yanmar 147, 1987 Model Made for USA (not a grey)
I am replacing the bearings in the alternator due to dust, dirt and bits of grass collecting inside the alternator. The bearings had got noisy but were still tight didn't let the rotor rub the windings. However, the dirt and stuff has polished off the green coating on about half of the ends on the stator.
I know this sounds like the bearings were letting the rotor rub the windings, but I got a lot of dirt out of it and the magnets aren't gouged or scored at all, so I really think all the the dirt was polishing things as it spun around. dirt was packed all around the magnets. Any suggestions if the ends need to be recoated (painted?) before I put it all back together? If they need painted, what should I use?
I got probably 3 tablespoons of dirt and stuff out of the inside of it.
Also can you still get any parts for the YCM-60A finish deck? I need the cogged sheave on the opposite end the discharge chute.
   / YM 147 alternator and mower questions #2
I would replace the bearings and paint the polished up areas with a good exterior metal paint, just to keep it from rusting or corroding.
I stock the cogged sheaves that you need for your YCM60A mower.
Contact me for prices.
Sounds good, I replaced the bearings last night and put a little paint on it.
Spent all of $12.00 for the two bearings and a new fan belt. Sure beats letting it go and having to buy an alternator!
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
2022 Bobcat T770 Skidloader (RIDE AND DRIVE) (A50774)
2022 Bobcat T770...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
Toro Workman Utility Cart (A51694)
Toro Workman...
2015 Peterbilt 348 T/A Fuel Lube Truck (A50323)
2015 Peterbilt 348...
2025 Platform Safety Basket Attachment (A50322)
2025 Platform...
