Tiller Yet another tiller question (will it fit?)
   / Yet another tiller question (will it fit?) #1
dbdartman
Platinum Member
central New Jersey (No. Burlco)
JD4400
A friend offered for free, a 48" JD tiller. :D Trouble is, it's a 12 hour drive one way to pick it up (NJ-Bar Harbor, Me). :( Before I commit to taking it, I need to know if it'll fit my JD 4400. :confused:
Serial # on the tiller is: M02902X538226 (any idea what year this is?).
I'm told it fits a 318, 420 & 430.
Being new to the board, & new to tractors, I have no idea what this tiller, or the recommended tractors, look like (anyone have a pic?). All I use the 4400 for is mostly cutting the 5+ acres of field around the house (Before the house was finished, neighbors called the police & complained about the over-grown field which had sat fallow for at least 8 years prior. Nice, eh?) & moving a little dirt. We have a tiny vegetable plot now (maybe 150 sq ft?), but with a tractor mounted tiller, I'd love to have one much larger (1500 sq ft at least).
So, should I do this deal, or keep my eyes open for a tiller more appropriately matched to my tractor?
My brother & I have built so many Mopars in the last 3 decades, there's not much we DON'T know about them (my specialty is 66-67 Chargers & 68-69 Darts), but when it comes to these tractors & accessories, I feel like a RANK AMATEUR! :eek:
Thanx!
David
   / Yet another tiller question (will it fit?) #2
I use a 4' tiller behind my 'bota L3400. It does not fit well but any means. I have to loosen the 3pt lift arms to the point where it almost feels ridiculous (they point in quite a bit) but it works. I got a 4' tiller so that I could do small areas as well as big areas. My tractor surely overpowers this tiller but I haven't broken it yet.
   / Yet another tiller question (will it fit?) #3
David,
Check the PTO speed. I did some research before I bought a used Howard Tiller 48" for my JD 2210. I think the JD 318 Ect PTO spins at a much higher speed than 540 rpm. I could be wrong, I just remember reading that somewhere. My 2210 will run the 48" Howard no problem, just the tiller is geared for a 540 rpm input.
Bruce
   / Yet another tiller question (will it fit?) #4
I see this thread is pretty stale, but thought I'd add my 2 cents from some things I've learned over the last few months of research. I have a JD2520 CUT and have also been looking for a heavy duty L&G tractor and was hoping to share some implements including a tiller. Here is what you hopefully have already learned:
1) Those tractors are are all 80/90's's L&G tractors and the PTO's are 2000 RPM (vs your 4400 CUT's's 540 RPM).
2) The 2000RPM PTO's rotate in the opposite direction from CUT's
3) They had category 0 3 point hitch's vs the CUT's category 1 (all different spacing and pin sizes).
4) Those L&G tractor's have about 12-16 PTO hp vs maybe 30 on your 4400. You would probably tear that tiller apart.
Bottom line as I hope you have found you DON"T want that tiller.
hemiguy, I passed on the tiller. With your info confirmation (2K RPM, reverse rotation), seems it was a good move.
Thanx!
JMR 72" Root Grapple (A50121)
JMR 72" Root...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
20' Sea Container (A50774)
20' Sea Container...
Bale Ring (A50515)
Bale Ring (A50515)
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
