Yet Another New Tractor Buyer
   / Yet Another New Tractor Buyer #1
warriordba
Hanover, PA
JD Sabre 2048
Hi all, I am like most trying to get the best trator for the money. I think I am settling on a Kubota probably the B7610, but how would you rate that against say a NH TC25. I have seen threads that say Kioti should be less but our local Kioti dealer seems to be higher than Kubota.
Despite a neighbor saing Deere has better resale, I think the best advice I was given was buy a tractor for keeps and ignore resale.
I admit I am tempted by low price/ high HP of the Jimni's but to be honest when you read between the lines of all the good stuff, most of the forum talk on them seems to be about finding parts, finding service fixing this and that etc so I am leary. Should I be??
I want the tractor mostly for the front loader and to attach a post digger etc. I might move snow with it in the winter. While I have 9 acres, much is wooded and the rest pasture. My little 2048 Sabre handles most of the mowing.
Thanks,
Glenn
   / Yet Another New Tractor Buyer #2
I think your not being too concerned about resale is a good idea.
If you have a Deere dealer around, it wouldn't hurt to look at them. They might be more competitive then you think (or, vastly overpriced...)
If you do look at Deeres, the only one I'd NOT recommend is the 3202 as that does not have a method to operate with the operator off seat. You might need that when you use a post hole digger.
Personally, I think the B7610 will be too small for your needs. I looked at the previous model, the B7500. Nice machine, but for 9 acres (depending on how much you intend to work)...bit small. So, while you're at the Kubota store, look at the B7800.
I'm sure you can get some good deals with the lesser known brands, but you do take the (bigger) risk of being an orphan when it comes to parts, service and reliability. It also depends on how much mechanical talent you have...and if you're OK with turning a wrench.
Nothing wrong with used tractors either, so that's another option.
   / Yet Another New Tractor Buyer #3
Glenn,
As far as your comparison of the NH TC and the Kubota, I will tell you this story.
When I was looking (purchased this spring) I asked my dealer about the difference. They sell both brands, and they had started as a Ford/NewHolland dealer long ago, picking up the Kubota line about 10 years ago when another dealer closed down.
My dealer said they weren't overly impressed with the NH's , in that class of tractor. he told me if i was going larger, he'd have me in a NH, but, in the smaller class, they tended to think the Kubota was better.
They had more NH's lined up than Kubota's, which he said moved off the lot more briskly.
I had already made my mind up for Kubota, before even walking into the dealer, based on my own research, but, after hearing him give his comparison, I felt I had made the right choice.
Now, before anyone thinks I'm knocking the smaller NH's , there is not a huge difference between them. Some of it is going to be personal preference.
You have to look at the dealership, parts, service, distance as well as the machine itself. If you have a NH dealer 15 miles away, and the nearest 'Bota dealer is 60 miles away, that could have a big influence on anyone's purchase! Same goes for Deere. Out of the 3 of them, in that class of tractor, I don't think any of them is vastly superior over the other.
It's just looking at Price/Features/Dealer/ and what you feel fits your needs best.
I'll add to what Roy said, you may need a bit larger?
Depends on how much of your 9 acres isn't going to be touched.
I'd look more at the B3030, or, dare I say...[gasp]...the GL3130.
Good Luck!! Post some pictures when it's delivered!
(Whatever you choose you'll be happy.)
   / Yet Another New Tractor Buyer #4
I thought that the John Deere's would be a lot more expensive too, but found that they really weren't. The direct comparison for the B7610 (which I have also looked at, and liked) is the JD2320. The best price I've gotten on a B7610 was $14,100 with fel. The best price I've gotten on the 2320 was $14,500 with fel, loaded tires, and ballast box. Since the usual charge for the loaded tires is $200 in this area, and the ballast box is $200, it's a wash.......... and you get position control, brakes that you can use for steering, drive over mower deck, and JD backhoe option that is not 3pt mounted ...... though it isn't the strongest hoe around. The loader hydraulics, and performance is smoother, and faster on the Kubota, and the optional front mounted attachments are a better match for the tractor size wise. Your call there I guess. If you are going to be using a post hole digger ( I have no experience with them) many like the clutch setup on the Kubota much more than the independent pto control on the JD. Lots of things to consider, but price shouldn't be a show stopper on those two choices.
   / Yet Another New Tractor Buyer #5
Are you sure a tractor is what you need? I would take a look at the power-trac models since they would be ideal for FEL and posthole drilling work if you're not doing any conventional ag that requires a tractor. They also do fine for mowing. Another possibility would be a used skidsteer, again champs for FEL and drilling holes.
If you do want a tractor, I will simply add my 1.5 cents that I looked at JD absolutely last because I had always assumed they were overpriced and not worth it. I changed my views 180 after seeing, driving, and pricing them, and I now own a JD. Not to knock any brand, but don't count JD out based on assumptions. I would generally agree to pick based on your use and not resale value, and I find the comment especially entertaining because so many people here claim that Kubota has better resale than all others.
   / Yet Another New Tractor Buyer #6
From your description of your intended work, the Kioti CK20 would be fine. It has as good a FEL as any of the tractors up to 30hp (stronger than the Kubota 7610) and 21hp should be fine for post hole digging.
What part of the country are you in?
Kioti pricing is often odd as smaller dealers often seem to think they can quote list price. The bigger dealers seem to be more realistic and price competitive. Undiscounted Kioti will often cost more than discounted Kubota or even JD. Discounted Kioti is generally quite a bit less so the goal is to find a realistic Kioti dealer (there are many including several on TBN who deliver interstate). You could also talk to the first dealer and ask him to beat the others. You'd be comparing to the CK20 (at bit less power than the other two but just as strong a loader and heavier). Again, it depends on the dealer but by shopping around you should be able to get the Kioti's for less than the equivalent Kubota/JD.
All the tractors that have been mentioned would do the job for you but I personally would not think more than a 21hp tractor with a good loader is necessary unless there are other tasks (eg mowing 9 acres) that you haven't told us about.
Hey folks, thank you for all the helpful replies. It helps a lot. To answer the last question, I live near Hanover PA. The best quote so far (from a Maryalnd dealer) has been 15,700 for the 7610 with FEL , 54 in mower and ballast box and 17,715 for the 7800 with 60 in mower and 60 in FEL. I probably will follow your advice and take another stab at a Kioti price as well.
Thanks,
Glenn
   / Yet Another New Tractor Buyer #8
Thanks,
Glenn
Did you try the Deere Dealer in Hanover...or Messicks in Abbottstown?
As far as prices...if you're OK with gears, you may as well look at the 790. That would be a B7800 sized tractor for the B7610 price (with MFWD and loader)
I used to work in Hanover, BTW. I normally deal with Southern York Turf and Tractor in Shrewsbury.
I'm in Windsor, about 25 miles east of you...
   / Yet Another New Tractor Buyer #9
warriordba said:
Hey folks, thank you for all the helpful replies. It helps a lot. To answer the last question, I live near Hanover PA. ..... I probably will follow your advice and take another stab at a Kioti price as well.
Check out Wallace Tractor in Lake Ariel, PA
   / Yet Another New Tractor Buyer #10
That's up past Scranton...a goodly hike.
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2014 PETERBILT 388 (A53843)
2014 PETERBILT 388...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
