Yellowjacket Hunting
   / Yellowjacket Hunting #1
sassafraspete
Platinum Member
not heaven but you can see it from here... Brown C
Branson (kukje) 4020, 40hp turbo
Ok, I am taking a few minutes for a morning break on this hot , August day in Southern Indiana. This is yellowjacket season here. Usually in late July, August, and Sept, these become a real threat to anyone mowing grass. Just walking around is no problem...however run a mower across the entrance to their hole , and you have trouble on your hands.
This is especially an issue with me, since I still use a walk behind mower to cut my grass.
Just last week, my wife who was on a trip at the time, told me over the phone to be careful out mowing because of the time of year. I assured her I would be careful. Well , no sooner than hanging up the phone and starting up the mower.... I managed to find my first nest of the season. Mind you , I can dance the jig pretty good after running over a nest. Anyhow, only managed to get stung once. I had just mowed over this spot a few days before....so it was just starting to get active. I could tell by the number of yellowjackets flying around that there were not many workers hatched yet. After just a few minutes , they had all gone back to the hole and one guard was stationed at the entrance to the dime sized hole. I quickly dispatched a dose of gasoline down the hole.
Well not wanting to suffer the same fate this weekend, I decided a good offense was the best defense...and this morning I went on a yellowjacket hunt. Any of you out there do this? Anyway, with a can of red spray paint in my hand, I walked my yard in a grid like pattern, surveying back and forth, looking for any holes, any area where grass was absent, and the glimpse of a yellowjacket flying. Anyhow, the hunt resulted in 2 more nests found which I marked with red paint. One was just getting active, so I think there were not many hatched in it yet. The other however had quite a lot of activity around it, and the hole was the size of a quarter and seemed well used, so I am guessing that will be doozy. I like to wait until dark and dump gas down the hole...but if the nest is not too active, will do it in the daylight hours.
I live on a wooded hillside, and for some reason these jackets like nesting on hillsides...probably due to water run-off. I used to dig them up with a shovel after gassing, and basically you have something similar to a hornets nest underground. One that I dug up had 7 layers of combs , filled with larvae. I would like to know how big these nests get in terms of jackets at their peak.... I am guessing several hundred.
Anyhow, as if the heat and humidity were not enough.... I have to deal with these things. I am trying to work up the fortitude to begin my weekend mowing work. I just hope I found all the active nests for this week.
For all of you out there bushogging.... keep an eye out just ahead of your tractor looking at your previous swath.... you will normally get stung the second close pass to the nest after you have initially stirred them up. It is not hard to see a couple hundred jackets swarming around the hole...just stay alert and keep yourself out of trouble.
As for me.... off to see how well my hunting trip worked.
sassafraspete
A picture of a nest. I tried to capture a picture of a yellowjacket coming or going , but they were just too fast for me. And I wasn't about to stir them up for the sake of a better shot.
   / Yellowjacket Hunting #3
Thanks for the heads-up... I haven't been paying attention lately. Too worried about what's going to eat the tires, than to what's going to eat me.
I get rid of mine by marking the spot of the hole and then waiting until just before dark. Placing a rag soaked in gas over the entrance and just walking away (don't have to light it) has worked very well for me... never had to make a repeat application. Yellowjackets seem to pull in the guards at night, and the rag can be removed the next day...
Pete.
   / Yellowjacket Hunting #4
If you had posted this before I cleaned out a ditch with my cutter and fel it probably still wouldn't have saved me from the sting on my eye and wrist. By that time I was about twenty feet past the nest which I disturbed with my fel pushing rotten pine stumps. They were swarming around me but before I could run I had to put both gear levers in nuetral and take pto out of gear and cut the key off. THEN I RAN.
   / Yellowjacket Hunting #5
A friend had a trick that he used for yellow jackets and "meat bees". He filled a 5gal bucket about 2/3rds full of water. Then, some dish soap was added to the water, to break surface tension.
He took a piece of meat, hung it on a string, and placed it so it almost touched the water in the bucket.
Theory was, that they would fly around the meat and soapy water. If they ate unabashed, they got a little heavy, and a majority would touch the water. With the minimized surface tension because of the soap, they plunked right in the water, and would drown.
I saw him use this technique out camping; seemed to work well.
   / Yellowjacket Hunting #6
Make a note to put out yellowjacket traps in the spring when the weather starts to get above 75 degrees. You will catch the queens at that time and every queen caught prevents thousands of the critters. I have been doing this for several years now and we have very few yellowjackets any more. I have seen 3 so far this year; before I started catching the queens we would see hundreds by this time of the year.
   / Yellowjacket Hunting #7
Just another afterthought for you, which may have not helped in your case... but, based on my personal experience while disking, just leave the tractor running, but shut down anything moving, and slowly walk away. My poor Kubota sounded like it was in the middle of a hail storm... seems like the big, ugly, noisy, hot tractor makes a much better target. I managed to get out with just one sting, but for what seemed like an hour or so, a dark cloud of yellow jackets on a suicide mission hovered above the poor tractor. After they calmed down as bit, I went over and shut down till dark.
Pete.
   / Yellowjacket Hunting #8
I once donated a lawnmower to some yellow jackets. After dark when it ran out of gas and they went to bed I went back and got my mower and gave them some gas /forums/images/graemlins/grin.gif
   / Yellowjacket Hunting #9
I have encountered enough nests now that I consider myself a professional jacket spotter. I can spot your yellow jacket nests from a safe distance of 50' in mere seconds with a quick perusal. It all started while mowing and after being stung enough times, you too will develop reflexes that not even Bruce Lee could match and a peripheral vision that a simple house fly cannot match. It is a learned ability, one I found myself forced into. I do pride myself on this great ability, perhaps my only true great accomplishment up to this point in my life, one I never knew I had until the little SObees forced it out of me. I am proud nonetheless. /forums/images/graemlins/grin.gif
   / Yellowjacket Hunting #10
Robert, I never heard of "meat bees" or of anyone using the trick you described, but when I was a kid and we had round concrete watering trough for the horse and cow, our honey bees (7 hives nearby) also got their water there. So it was quite common for us to find dozens of honey bees floating in the water. And we'd just scoop up a handful and stand there, letting them "buzz" their wings until they dried enough to fly off. I was very reluctant to do that at first, but Dad didn't give me any choice. /forums/images/graemlins/tongue.gif And I never got stung doing that.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Magnum 125 Generator (A53421)
Magnum 125...
