Yellow waxy material in radiator reservoir of my Kubota RTV 900
   / Yellow waxy material in radiator reservoir of my Kubota RTV 900 #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I hadn't looked at my radiator fluid level since last summer so I thought I had better check it for freeze temp. I opened up the overflow reservoir and the top had a yellow greasy/waxy substance all around the neck and on the suction hose. It has swelled the hose to the point that it just fell off the top. I managed to fish it out and reverse the hose and the bottom half wasn't swelled from the oily, greasy yellow substance. It hasn't has the fluid changed since new but it still showed good to as high as my gauge went (-40) but it was a bit rusty orange looking. I bought some Prestone today to change it out with as soon as we get some decent weather. I just don't know what the yellow gunk was. Any one ever see this stuff. I suppose it could have been some kind of algae but it sure looked just like soft margarine. I have never put anything in the radiator not even water and it was clean last summer.
   / Yellow waxy material in radiator reservoir of my Kubota RTV 900 #2
Does the radiator have a cooler for say the tranny or power steering? Reason I ask is both my father's Corvette and my friends Cadillac have both had the transmission cooler fail in them. My father got lucky and the tranny fluid went into the rad. Mt buddy not so lucky with the caddy. It pumped the coolant into the tranny and cost $4000 to fix.
Do some investigation.
Chris
Chris
Thanks for the insight. I will do a bit more looking at the problem. I plan to change out the anti-freeze. The RTV has the radiator stuffed in up under the seat and it is hard to see what all it tied into it. I didn't think to check the transmission oil. I will do that also.
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
