YEEHAAAW!!! Thom2's Log Splitter WORKS !!
   / YEEHAAAW!!! Thom2's Log Splitter WORKS !! #1
Thom2
Tennessee
JD 2355
Here an update on the Continuing SAGA of the JD log Splitter.
1) Installed the plug in the Control Valve to make it a Closed Center.
2) Hooked the hoses to one of the dual QC remotes. It moves but pressure was erratic. (Max pressure 500 psi)
3) Moved hoses to the other QC remote and TA-DA. 2200 psi and the splitter busted a knotty log in a few seconds.
The #1 remote must be bad or the QC need replacing. I hope it's the QC, so it doesn't cost me an arm & a leg.
Thanks for everyone's help. ---Thom
   / YEEHAAAW!!! Thom2's Log Splitter WORKS !! #2
Glad you got it fixed.
If you had put a gage in the QD's as suggested, you would have found the problem earlier.
   / YEEHAAAW!!! Thom2's Log Splitter WORKS !! #3
Why a new thread?
Does this tie back to another on-going thread? Might be nice to link to it, at least, to get the whole story (better yet, to add to the other thread, presumming there is one :) )
   / YEEHAAAW!!! Thom2's Log Splitter WORKS !! #4
Yes this does tie back to another thread. Do a search for Thom2 .
   / YEEHAAAW!!! Thom2's Log Splitter WORKS !! #5
Too bad you wasted all this time and money on a new valve and cylinder for something as simple as a bad Quick Connect.
Chris
2025 AGT SDA-140T (A50123)
2025 AGT SDA-140T...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2025 CFG Industrial KKT(A)27 (A50123)
2025 CFG...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
